Hello, I'm new in this forum and this is my first post.
I would like to know if anyone is experiencing the same issues with the Diablo DAC and USB-AudioPlayerPro.
I tested both with and without the external dac (see below) with a few test tracks
Set-up 1:
Samsung Galaxy Note 10+, OTG cable C/A, USB cable A/B, iFi Purifier3, iFi Diablo, Beyerdynamic t5p
Test track 1: Jennifer Warnes/Way Down Deep (MQA)
The Diablo switches between Green/Magenta for a few seconds, then turn to (constant) Green.
Sound is very noisy!!, like 'shot noise'
UAPP Says: USB DAC 44.1kHz
MQA FLAC 44.1kHz 16bit 709Kbps
Test track 2: Cue/Burnin' (no MQA)
Diablo constant Green
FLAC 44.1kHz 16bit 879Kbps
Test track 3: Bob Dylan/The Man In The Long Black Coat (MQA)
Diablo constant Magenta
The 'shot noise' is gone!
UAPP Says: USB DAC 48kHz
FLAC 96kHz 24bit 1578Kbps
Test track 4: Bettye LaVette/I Hold NO Grudge (MQA)
FLAC 96kHz 24bit 1634Kbps
Changing the set-up to
Set-up 2: Samsung Galaxy Note 10+, USB C/3.5mm, Beyerdynamic t5p
...and running the same Test tracks gives the following:
Test-track 1:
Test-track 2:
MQA FLAC 44.1kHz 16bit 879Kbps
Test-track 3:
UAPP Says: USB DAC 96kHz
MQA FLAC 96kHz 24bit 1578Kbps
Test-track 4:
MQA FLAC 96kHz 24bit 1634Kbps
Seems that problem is correlated to the 44.1kHz(??)
Anyone having the same problem?
IFi-support seems to believe the problem is on the UAPP side.
UAPP-support says it's an issue on the Diablo-side...
Set-up 1:
Test-track 1:
Test-track 2:
Test-track 3:
Test-track 4:
