elliot42
- Jul 18, 2008
My CF modded iPod Mini was working fine up until the other day when rockbox acted weird a few times when using the file browser; the filenames were all garbage. When I hooked it up to a computer it was a bit messed up; my parents' Windows box would have nothing to do with it, didn't mount any volumes. My box, booted to Windows XP mounted it, but started having io trouble when using the volume.
Using Linux, dmesg showed me that it seemed fine, mounted, but later on gave me IO errors and problems with the file system.
I have restored it multiple times, both with iTunes (which partitioned it funny, the firmware partition didn't end on a cylinder according to fdisk), and manually with fdisk, dding the iPod firmware in and formatting the main partition to Fat32.
From this point, iPod firmware loaded and I could put music on it with iTunes, but when I reset it with Menu+Select it asks for the language selection again and doesn't save any preferences. I put rockbox 3 on it and the installation went fine but when I restarted the rockbox bootloader took ages and finally came up with a 'Partition not found' error.
I have checked and scanned the card (16gb PQI 120x CF) with HDTune and there are no bad blocks, it has an absolutely rock steady read/write speed, fast and uniform access times. The same thing also happens with different iPod Mini logic boards.
Any ideas on what could be wrong and how I can fix this?
