dokebi
- Mar 25, 2002
I finished building my first cmoy. It worked perfectly the first time and I left it naked for a day playing. I then added a power switch and put it inside a case. The problem is that the battery becomes very warm as soon as I turn it on and a fresh 9volt dies very quickly. I suspect it is how I attached the power switch or a grounding issue. I also tried my rechargable 9volt and I think I destroyed it. It actually bulged out as if was going to explode. The switch is mounted on the project box and I attached both the battery leads and the power leads of the amp to the switch pins of which there are 2. Shorter one is fo negative yes? Does this problem sound familiar to anyone?
