I'm sorry about this matter. All units had been test and burn in for 24 Hours before and sure had test all funtion. It may be some time cause by cold solder. I'm sure the component had no problem. All material is order direct from manufacturer like Nichicon , Nippon Chemicon , MIT , JJ .... All tube had been tested when arrived factory. Most tube also burn in for 8 Hours before test (Except Direct Heat tube, It filament become easy broeken after burn in e.g 211 , 845 ,300B). We only test it !
I had try to improve the quality control and keep the workers stable. Most of the wokers had been work for 2 years or more and good experience. We use Solder import from Hong Kong large solder supplier co. (Alpha metal). We will 63% Zinc and 37% Lead. It is the best solder in inductrial . (Excep silver solder , It is too expensive and not possible to use it soon.)
I like to listen more comment on our products and any idea to improve its is welcome. Bye ! I will be in Las Vegas T.H.E show in Tuscany Hotel. May be can meet someone.
