SonicScientist
- Jul 3, 2012
I hope this is the right place to ask, this forum isn't exactly fluid on a tablet. Anyway, I recabled Grado sr80 a while back with Canare star quad and a straight 3.5mm Amphenol plug. I'll fetch the model numbers later if they're of importance, but they're the usual stuff recommended even here. The problem is that if I wiggle the plug or the cable near it the sound either disappears from one channel or it loses both ends and becomes distant. But this only happens with my pc. I have an extension cord of the same cable terminated with Neutrik plugs and a short one from Jays headphones and they have the same problem, but only from the pc.
The sound is fine from my Nexus 7 tablet with and without the ext. cables. For some reason the jack won't fit my Nexus 4 phone. 2 other headphones with stock cables work well with all the configurations. Grados too worked well with stock cable, but I've changed sound cards since then. The current one is Xonar DG by the way.
I don't know too much of this, but it feels like some kind of weird grounding problem. Anyone got any idea? I should probably solder in a new jack, but at the moment I don't have means to close the housings if I opened them for figuring out the channels.
E; looks like there was a diy forum after all. Oh well.
Copy pasted this there into an appropriate thread. Admins may do whatever they wish to this one.
