Filburt
- Jun 23, 2005
The dual LM6171 is the 6172. I do not recommend the OPA551 unless you absolutely must use it as it's too slow for most of the op-amps we're looking to couple with it.
Hopefully the LMH6321 will sound more like the LM6171/2 sonically than the BUF634 as, IMHO, the BUF634's colouration of the sound isn't particularly suited to some of these op-amps. I don't personally like the 634 on practically any amp I've ever heard with it, and the ones I didn't dislike it with I still felt were lacking in some manner, so I'm probably going to stick with the LMH6321 or something else if possible (and provided they sound better).
Another op-amp you can try, if you can restrain yourself from using 2x9v (12v supply max) is the LMH6622.
Originally Posted by ATAT The 2107 is the opamp of choice for filburt. he's been raving about it, and since the 2107 is a low output current, high precision, low noise, its basically nearly ideal for the PPAS-type topology (compared to high current, low precision stuff..). Of course, this is all untested and therefore just speculation. but as soon as I get my boards over in japan, I'll test out the follow'in Opamps - Signals - AD8620 OPA2107 OPA2227 OPA2134 AD8066 LM6171 (dual) Grounds - THS4621 (or something.. forgot the exact #..) LM6171 (yes, its an "unstable" opamp..) AD8610 LM7171 Buffers - BUF634 OPA551 LM6321 Any other suggestions? |
