ozshadow
- Apr 29, 2006
n/m
Originally Posted by ozshadow Jameco has BUF634P in stock which should work if you bend the lead tips flat and level. |
Originally Posted by ozshadow Also, for those of you with a built version, is there enough room to use 6x11 caps on the opamp rails instead of the 5x11 listed ? This must be absorbed in width of the board and not pushing the other caps outward. The reason for this is that I need 16v caps instead of 10v for the charging/power circuit which will be splitting approx. 27 volts. There is a Panasonic FM cap in 120uf 16v that is 6x11 - one extra mill in diameter. |
Originally Posted by ATAT Wideband mode is undocumented - jumper to the left of the right buffer and below the pot is the bandwith jumper.. jumpering that gives wide bandwith mode while keeping it open leaves it in low draw mode quicksilver - I havent got a LMH6321 config working yet so my post was speculation from the datasheet. the simplified schem shows ground being used only as a reference for the error pins (makes sense, since that error signal's gotta be referenced to something) and the rest looks just like a beefed up BUF634 (and therefore not needing a reference point midway the supplies.. For the LM6171 and such, no adjustments were made I will put the appropriate resistors to match bandwiths but the amp is stable at stock configuration. |
