jamont
- Nov 10, 2002
Domo arigato!
Originally Posted by tangent Hai. |
Domo arigato!
Originally Posted by morsel 6mm = 236mils. This may be enough clearance if the C1 electrolytics are not fatter than 500mils. 18mm = 709mils. They may not seat since they will be touching end to end at 700mils, on the other hand, they may actually be shorter. Longer and shorter caps could be alternated to circumvent the length issue. Bottom line: We won't know until someone tries them in real life, because these parts often vary substantially from their specified dimensions. I'll add the pads. Since our development list has been quiet I thought it would be a good idea to mention the following issue: Tangent asked for the center LED pads overlapping the bass boost pot. PPL expressed concern that leakage currents and capacitive coupling might be a problem. I don't care if we keep the extra LED pads or not, but observe that the LED is not a dynamic load. If it is really a problem then of course we should get rid of it, on the other hand, why sack a requested feature needlessly if it is harmless. Thoughts? |
6mm = 236mils. This may be enough clearance if the C1 electrolytics are not fatter than 500mils. 18mm = 709mils. They may not seat since they will be touching end to end at 700mils, on the other hand, they may actually be shorter. Longer and shorter caps could be alternated to circumvent the length issue. Bottom line: We won't know until someone tries them in real life, because these parts often vary substantially from their specified dimensions. I'll add the pads. |
