BradJudy
- Jun 26, 2003
Hmmm...I don't see how that answers my question, let me rephrase it.
If I have two sets of inputs, should the input ground of both sets be tied to each other and then the case, or only tied to the case when that particular input is selected? One way means I isolate the inputs and then tie the input ground coming from the switch (or at the PPA) to the case, the other way means I don't isolate the input jacks and both input grounds are tied to the case at the jacks.
Originally Posted by morsel Whether single or multiple inputs, my answer is the same. All signal grounds are tied together via the audio interconnects. Unbalanced equipment that ties AC ground to the case and/or signal ground is a liability as it may cause ground loop problems. The goal of quiet unbalanced equipment is in direct conflict with the goal of satisfying AC grounding regulations. In the USA most unbalanced equipment is 2 prong. Making a device as small and low power as a headphone amplifier 3 prong is just creating a giant nuisance for yourself. |
