Feb 27, 2009 at 7:56 PM Thread Starter Post #1 of 5
Dominat0r
Formerly known as HighLife
Hey guys, been noticing something odd. I flip on the switch for my millett hybrid (tyll knows i have the first one made, millet is spelled wrong.) however sometimes, not very often it will power off right away, i have to push the switch up again to get it to power on.
Is the switch going out on me?
Tyll, jorge hope to see you both at canjam 09 =-)
Dom-HighLife
Feb 28, 2009 at 6:06 PM Post #2 of 5
Dom, it could be something simpler like the switch is dirty. This is more of a problem if you smoke or open the windows which allows dirt to come into your listening area. You could remove the power switch and flip it a few times to see if it self cleans. Or if you have compressed air of tuner cleaner you could use them.
Good luck.
Feb 28, 2009 at 7:52 PM Post #3 of 5
Thanks miguel, ill have to check how to remove it
Mar 1, 2009 at 7:14 PM Post #5 of 5
thanks tyll, ill do that...
