A3rd.Zero
- Dec 27, 2001
I just built a basic rail splitter powersupply for a 9v battery (2 47k resistors, 2 420uf caps) and I am getting a significant difference in voltages in respect to the ground, some times as much as .8 volts. I switched to a small wallwart added two 2200uf caps and one 6800uf cap from the positive to the negitave rail, and i still am getting differences. The weirdest part is that its not always as bad, sometimes the rails are only off by .3 volts. Is there something that i am doing wrong? Do I just need to build a better railsplitter using FETS or Buffers? Thanks for the help.
Milo
Milo
