ECM
- Jan 9, 2004
I started building a power supply with a 10-0-10 center tapped transformer. when i measured the actual output without a load it was 11-0-11 VAC. i built a bridge rectifier and added some caps (1100uf). when i tested the DC output of the rectifier and caps it was +/-15V. how can that be? will the voltage decrease once i add a load?
