Reader
- May 13, 2004
In most home power outlets are 2 set together on one panel, now I plug my monter cable into the outlet which in the same panel with the outlet my frigerator pluged in, will it affect sound come out of my system? Should I change it to other outlet? Help please. Thanks.
Edit more question
Now since I can't(shouldn't) use the same circuit for fridge or my PC and Speakers, it's inpossable to have my DVD player and Amp plug into different circuit, does use different outlet from same circuit heap?
Edit more question
