haejuk
- Dec 4, 2003
I am putting together parts to build an O2 amp and I found that one of the parts is already obsolete. The power jack (Kobiconn #163-7620-E) is no longer made. I searched around and found no one else has ever mentioned this before which makes me think I am probably just too inexperienced with builds to find an easy solution, but thought I would ask. There is a possible replacement (Kobiconn #163-7620E-E), but that won't be shipping untill June 6th or so.
The point: Does anyone know of a 2.1mm pcb mounted power jack that will be able to replace Kobiconn #163-7620-E in an O2 build, preferably one that is in stock at Mouser?
Thanks.
Edit: I got a PM recently asking about how I got a power jack. I had to get one from JDS labs because at that time (around April) the replacement power jack was still a couple months out, I think it was supposed to ship around July and I didn't want to wait. I think you can use Mouser part "163-7620E-E" as the replacement for this part. This info is from JDS labs, so I assume it is what they are using right now.
Thanks.
