hey oli just an afterthoguht about our discussion earlier. Are the heatsinks as large as the capacitors or larger? If so you could use thermal epox to glue an aluminium sheet accross the top of the psu. I think that would do wonders in a case with no airflow. If the caps are larger then mayb a cutout in the plate would do the trick.
It won't do anything for removing heat in the case but it will help draw heat away from the sensitive components.
