OK, I assume you will have a pressure cooker so will present you with the top secret Porcupine meat ball recipe
Don't be put off by the simple ingredients, this really is one of the tastiest dishes ever and one of my favourites.
You'll need:
1 tin of cream of tomato soup
1lb of mince (ground beef)
1 teacupful of American long grained rice
1 onion finely diced
1tsp salt
Black pepper.
told you it was simple.
First off wash your hands. Pour the tomato soup into the pressure cooker.
arm yourself with a mixing bowl and add the beef, rice, onion, salt and pepper into the bowl. OK now go wash your hands thoroughly and scrub your nails. (always do this at every stage of cooking...... it becomes second nature)
Go back to the mixing bowl and squeeze the ingredients through your hands ensuring everything is mixed together evenly and tightly.... when I say squeeze I mean take a handful and clench your fist to force the mixture out of your hand..... you are in effect mixing and mashing.
When you're happy everything is evenly mixed go back to the sink and wash your hands again leave the tap running..... this time return to the mixing bowl with wet hands (this prevents the mixture sticking to your hands) form the mixture into balls, bigger than a grape but smaller than a golf ball, and add them into the tomato soup..... keep returning to the tap to keep your hands moist.
You've now got a pressure cooker containing tomato soup and balls... easy as pie. Now bring to the boil and when boiling stick the lid on the pressure cooker, bring up to maximum pressure and cook for 15 minutes..... turn off the heat and let the pressure go down in it's own time (about 5 minutes) don't depressurize manually..... let the cooker do it, it's all part of the process and the secret to a truly great porcupine meatball.
Voila! get your teeth into one of those and I guarantee you'll be hooked for life.
They are best served on a bed of buttered and peppered spaghetti (cooked until it's al dente') grate some fresh parmesan over them for a more intense flavour.
They're also surprisingly good served with boiled potatoes.
I've cooked and conconcted many recipes over the years ranging from simple to positively exotic and I can seriously say that time after time this recipe is, by far, the easiest to prepare and the most delicious to eat....
Great thread BTW. I hope it lasts and becomes a good reference point for interesting recipes, I'll be back next week with something a tad more adventurous
maybe get you started with dough and the secret to making a "good" dough.... dough is a very important component in pizza making which I'll cover in depth further down the line.
All the best and welcome to the world of culinary alchemy
Mike.
EDIT: sorry I didn't explain "Al Dente" your spaghetti should be cooked but still have a "bite" to it...... a good way (the only way) of ensuring your spaghetti is spot on is to take a length from the pot and throw it on the wall (or ceiling) if it adheres to the wall then it is ready........ if it says 10 minutes on the packet (if you're using dried stuff) then start throwing it on the wall after 7 minutes...... once it sticks it's optimum.
