amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
Yes, in a Mini³fied PINT, the output DC offset will vary a little bit with the volume control.
As for the 1KΩ resistor value, it was computed based on the pot at minimum position, so the equivalent resistance there is 100KΩ in parallel with 1KΩ, which is 990Ω. The R4/R3 values of 6.2KΩ in parallel with 1.2KΩ gives 1KΩ, close enough to 990Ω so that it's balanced. At maximum volume, if the source is direct-coupled, then its output is essentially ground because sources tend to have low output impedance, so the situation isn't much different than the minimum volume scenario. For sources with output capacitors, then the noninverting side's equivalent resistance at max volume is 100KΩ in parallel with 11KΩ (the pot + the 1KΩ resistor), which is 9.9KΩ. This might seem unbalanced from the 1KΩ equivalent resistance at the inverting side, but since the resistances are low, the voltage developed across them (due to input bias currents) are small, so their effect on DC offset is also relatively small.
No, unless something is wrong (i.e., oscillation).
Originally Posted by threepointone i know, but i was just wondering where this magic number 1k came from. a current is forced through the resistors in the noninverting input from signal to ground, so (at full volume) shouldn't the resistance to ground just the 100k resistor and 1k + 10k pot in parallel = ~10k in order to balance the noninverting and inverting inputs? So that would also mean that the DC offset can vary as you change the volume or with different source output impedances. |
Originally Posted by phobus Is there supposed to be a temperature difference between the "regular" PINT and the minified version? |
