ashy79
- Apr 4, 2008
hi... my speaker's woofer will auto mute when bass level is high enough...
opening up.. the woofer's amp... has this power relay... it seems that it's sensitive to vibration... i tried to knock lightly on it and it auto on off on off.... sorry... have null knowledge in electronic... a proper power relay should not react to vibration right? only short circuit or something right?
the spec sheet
MASSUSE ME-140FF
- 10A switching capabilities
- 2 Form A and 2 Form C configurations
- 5KV dielectric strength from coil to contacts
- Open contact distance more than 1.5mm is
available
- UL and CUL approval, File No.: E179936
btw, i just received the speaker from postage... pls help out.....
the spec sheet
MASSUSE ME-140FF
available
![frown.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/frown.gif)
