Romanee
- May 20, 2004
Be super-patient. At 270 hours, on day 2 (Sunday) of the National Meet, it sounded very good, but still needed a tiny bit more clarity up top, and more punch and definition at the bottom. The sound was fully matured (stabilized) somewhere between 300-350 hours.
Black Gate caps can have weirdly erratic segments in the "burn-in" process. I've experienced some of those that made me really anxious that the sound had gone terribly awry -- but I had just enough fortitude and patience to expect it would probably clear up -- and it did.
As good as you feel it sounds now, when it has passed the huge number of hours I noted, the sound may astound you. Even if you don't notice what I mean right away, if you listen to some other amps and then switch back, the unique and complex layering effect will become apparent. On some recordings it will feel as though all sorts of sounds are whizzing around your head. That seems to blossom when the top end clears up and much more of the subtle and complex overtones & harmonics that make up ambient and spatial cues, as well as timbral structure, come through -- along with more inner detail. I find that both LF and HF percussion instruments are not only better represented, but I can hear more distinct notes rather than just the percussive strokes -- even tympani and high-hats.
Of course it's not the be-all and end-all of portable amps, but it is a unique and beautiful sound. It's not perfect and it has some limitations (which a larger case and more power might help improve), but it has come a huge way since the first Portaphile -- even since the original PV2^2 -- and it really takes all the upgrade components to get there.
I'll be interested to read your final impressions. Try to keep it playing 24/7 if possible. I used my entire iTunes library set to "repeat all", and whatever phones were available each day. My Powerbook got really hot, but it was worth it to get the huge "burn-in" period done with ASAP. Of course I listened along the way, and carried it to work when practical (most of the time).
I find the "burn in curve" of a new amp rather entertaining, but it can also be painful torment filled with anxiety and angst! Enjoy (and remember to be patient if it takes some weird twists and turns before it reaches its goal).
[I've taken to putting "burn in" in quotes since it was pointed out by a more technically-savvy member that nothing's burning...]
Originally Posted by nelamvr6 Holy cow! I am more and more impressed with this little amp every day! I'm using the PSU I linked to in the post above, I still only have about 40 hours on the amp so far so I expect it will get even better! The noise floor on this thing is incredible! The sound just effortlessly springs forth from a silky blackness. The dynamics are superb, probably due to those huge BlackGates, the multiple buffers and the LT1210. The clarity and resolution is excellent. This thing is starting to sound almost as good as my home amp! |
