SM88
- Aug 13, 2014
I currently have the AKG K845BT and i think they are amazing in sound(from wire use not the BT option) and build quality , my only problem with them is that they are not really portable .
i am looking to upgrade from the AKG K845BT or to get something similar to them just more of a portable option .
i will be using the headphones without AMP just from my phone , the music i listen to is EDM and Indie/alt rock .
thanks in advance
thanks in advance
