PlQuote:
Aah I see. How would you say an Itouch/ Ipod compares with a standard onboard sound?
Hmm how to explain... onboard sound normally does not differ high and mid tone good, bass is much but also not precise, you can´t differ single tones, its overall mashy. Imo quality of an 20-30€ supermarket player.
My good old Sansa Clip V2 (without Rockbox because theres a noise bug with the V2) has a nice setup, good bass, ok mid and high tones, 5 band equalizer.
An IPod Nano 2G (quiet old) has not that much bass, it´s not that rich, but also precise. Mid and high tones are a nuance more precise then on the clip, i can hear f.e. the audience on an live concert better differed then on the clip. But it does sound a little little bit unnatural for me (dunno why), and there´s no equalizer, only presets which I dislike.
The Asus Xonar Essence STX internal sound card beats em all.
Cowon Z2 will arrive next days (hopefully^^)
Please note that all was tested with an AKG K701 (imo greatest headphones for natural, linear sound, but open system, you can´t use them in public) and UE´s Triple.FI 10 (great for three way in-ears).
With my old Sonys for around 60€ the difference is harder to hear, and the sound is not really natural.
When your headphones / in-ears are "cheap", i´d
always prefer to buy a combination of good headphones/in-ears and the Sansa Clip+ as an mp3-player for the start,
then an 100€+ mp3-player and cheap headphones / in-ears or the ones of the player.
The Sansa Clip+ (+ Rockbox) is close to good mp3-players (even to apple or cowon), while headphones for the same price (around 50€) are more far away from the sound of 200€+ headphones
(in-ears the Triple-Fi 10 are very famous, problem is you can´t test in-ears in a shop or send em back to amazon if you dislike em; for headsets: try some and find the one matching your sound characteristic favor, makes a big difference).
Sorry for my bad english^^
