Jmstrmbn
- Dec 8, 2009
Hey everyone, I have had this issue in my system for a while and it has me confounded. If any of you could offer advice to relieve the issue I would be quite grateful .
So my setup is Audirvana Plus going out from my Mac via an M2tech Hiface 2 to a PS Audio Digital Link III. If I change from a song or album that has a different sampling rate there is the normal quiet clicks associated with Audirvana and an occasional loud snap in only the right channel. The DAC has a signal lock feature and I believe it gets confused when the Hiface suddenly reads a new sampling rate, especially since the signal is stopped as the sample rate is switching. This also occurs more rarely in the middle of songs when for some reason the DAC loses the lock on the Hiface.
For now I am going to try having Audirvana up or down sample everything so now sample rate switching occurs regardless of source material. I've also set the pause time for sample rate switching to 3s prior to setting a global sample rate which did not help much at all.
If anyone has experience with this kind of quirk I would really appreciate the help!
Thanks!
John
Thanks!
John
