brighteyes1170
So here is the flow of my setup at the moment,
MacBook Pro -> Aune X1S -> Little Dot MKII -> Aune X7S -> Sennheiser HD660S
So the issue that I am having is that when the volume on my laptop/iTunes is at full volume the sound begins popping very badly and sounds like there is a lot of static. I did not have this issue before adding the Little Dot into the mix. Previously when I had just the X1S and X7S I had the volume on my laptop at max with no issues and just controlled the volume with the X7S. Is it normal for that to happen or is there something wrong with my Little Dot or the tubes in it? Will it go away with time as the tubes "break in"?
