Originally Posted by IPodPJ /img/forum/go_quote.gif
I have mixed feelings about power conditioners... they often do as much harm as they do good.
Like how?
Yes, and the new PS Audio PerfectWave power plants have an 85% - 90% efficiency so I'm not sure where Gilmore is getting his figures from.
50% efficiency would be horrible and I can't imagine anyone wanting to use such a device.
I do think regenerators make a positive difference overall (some items don't work well with them, it just depends on your component). I have a P5 and I think it's a nice step up from their old model, the PPP, which wound up dying and frying some of my gear. The P5s are also made here in the U.S. so that's nice for a change.
Like how?
The PPP I feel is an example of "it depends". I tried to audition it against the Audience, but didn't because 2 high end dealers stopped selling it, One because their customers reported squashing of dynamics when using power amps (but source equipment was fine). The other because of the occasional frying issuewhich, in the UK at least, only happened in a particular mode when power amps in use. PS Audio seem like a good company and I think they've changed the design since then, but I haven't been following the story for some time.![]()
Is anyone here familiar with units like the PS Audio Duet, Shunyata Hydra 2, Furman AC-215A, or anything similar? Would they offer any benefits for a simple 2 component system consisting of a Sony SCD-XA5400ES SACD Player (with VSE Terra Firma Lite Balanced Upgrade) and a SPL Phonitor? I'd be open as well for more costly options if necessary. Or does it make more sense to just buy a cheap power-strip from the local hardware store?
Thank you so much for your help. Like many others with no experience on the subject, I was inclined to think that the more expensive Hydra would be more effective. I'll research the ones you mentioned, the Silver Circle Juice Box Jr, PI Audio MajikBUSS, and B-P-T CPC, but at this stage, I'm inclined to follow your recommendation and go with the PS Audio Duet. Again, thanks for your input on the matter!
Sure. Another option you may want to take a look at is the Audience Ar2p. It's a bit more expensive than the others, but it plugs straight into the wall so you do not need to buy a power cord for it (good ones are $150+).
I actually saw the Ar2p on sale while looking for the Duet. The problem for me though is a lack of space near my wall outlet. Thanks again!
PS: I'm still in shock over your revelations about the Hydra...
Gotcha.
This is what the inside of the $1,000 Hydra 4 looks like. Two outlets with one suppression cap each, a couple of buss bars, a switch, and a MOV. Thousand bucks. Just amazing. [...]
For comparison, here's what goes inside Audience's AR6-T: [...]
Some help, some hurt, some do absolutely nothing.
I had a PS Audio Duet, it did absolutely nothing to the sound. Absolutely no difference between it and plugging into the wall with any product I tried.
I had a Monster power conditioner that helped with digital gear [blacker background] but at the same time hurt in dynamics [lost some crispness and depth in sound-stage]
I have a AGD power filter that helps digital gear with the 70db filter outlet, helps my tube gear on the 50db filter and seems to not make any difference with the DC filter outlet.
Of course my answer will not represent everyone's experiences, ymmv, synergy is the key......etc etc etc
Most products at the $250 level do a lot more harm than good.
