jlbrach
- Jun 4, 2005
i have a 200GB card on order for my Titan 120 as well and hope it will work as well
I will say the one thing that really annoys me is when you buy a 200GB card that is really only 183GB of space on the card...I do not understand what it is that takes up the other 17 GB since there is no operating system of any kind as there is with for instance the 240's internal storage....
The 200GB cards work in the Sony A17.
Just wanted to put it out there, the 200GB micro sd has not worked on my AK240 so far. Trying to troubleshoot in the meantime
What's the reason?
Is it because of too much loading time that wasn't expected when AK guys built AK240?
AK's website doesn't list 200GB microSD as supported. It still says 128GB max.
It shows only a small percentage of the files I loaded onto the card. I am going to reformat the card later and try once more. I also have a second card which I will try in order to confirm the card is not defective.
I loaded about 100 GB of music onto the card. It shows about 6GB
Are you using FAT32 format.
You have to format your microSD into FAT32 when it's more than 128GB. Otherwise, it will malfunction or crash.
the 200GB card works fine on my 240
i had a problem at first because when I loaded my music onto the card the first time it apparently loaded a bad file which kept the 240 from reading the card...when i deleted and reloaded the card everything was fine
