MoJoWales
- Aug 18, 2008
Hello,
I have a pair of PMX-80's that have the right speaker dead after cutting out for awhile. The speaker sounded just fine when working which makes me think that it is a cable connection issue. These are pretty new phones and sounded like the real deal, I bought them through a private vendor/seller off Amazon. Anyway, if it is economical to re-cable and end up with a more rugged, better sounding set then I will and I am looking for advice on others experience, cable used, guides, other mods to these phones... I am outside of the three month warranty window from the seller and the cost of just buying a new set of phones is not an issue. If I can build a more rugged headset with better sound for less money than I can buy is what I am after but is this a good set to do this with? I can solder and fabricate as needed. These are used with a Sansa Clip + and are mostly for working out and bike riding.
Thanks,
MoJoWales
Thanks,
MoJoWales
