Sep 22, 2021 at 9:34 AM Post #153 of 157
Thank you hi-fi amateur for starting this thread. I bought my PMV several months ago and never opened it along with some others that I had purchased around the same time because I got busy with some more high dollar ones. Last week I was looking for IEMs to use while breaking in my new Satin Audio Zeus cable. Yesterday was about 150 hours of break in and the PMVs sounded great. I switched the Satin Zeus out for a more appropriate cable, a PWA # 10. It was a good choice. Although both cable and PMVs were broken in, I let them cook for 24 hours and they now sound 99% of the Zeus combo.
NOTE: Dynamic driver and Planar IEMs and headphones need at least 100 to 150 hours of break in. Find a music source on the internet on your computer. Add an USB out to a DAC and amp and tune the volume to a reasonable level. One of those DAC/amp combos would work like a champ. Do not make snap decisions about new IEMs and headphones until you do a break in !!!!!!!!!!!!!!!!
Dec 12, 2021 at 8:14 AM Post #154 of 157
Got PMV PP as a gift before Xmas. I like the sound, similar to the entry-level Hifiman HE350, but with less punch in the base.
BUT, last week, the right side sound level dropped by a lot. The cable checked out.
I emailed Linsoul for a replacement, just the right side. They asked me for an order number which I don't have because it was a gift. Still talking to Linsoul to resolve it.
Update:
Linsoul said: no order number, no replacement. That is the end of the road for me. What a shame!
Mar 27, 2022 at 4:41 AM Post #155 of 157
Update:
Not able to get the gifter to have a look into it for you? I am sort of curious about the construction are you getting rid of them?
Mar 27, 2022 at 5:47 AM Post #156 of 157
Update:
check the air hole or the nozzle.
volume drop sometimes caused by blockage in the ventilation hole or the nozzle.
