ichobi
- Apr 17, 2007
Hello guys, as you can see am a newbie here and to audiophile world. Disclaimer : English is not my first language.
After reading and searching head-fi forum for 2-3 days, i have yet to get a good answer to my question.
Here is the situation
I'm living in a small dorm room, basically using Grado SR60 with MBP (analog output). However i found using headphone quite cumbersome since I have to move around my room when I work (and that's when i listen to music).
So, i'm finding a good pair of bookshelf speakers and whatelse do I need to get good sound out of my Macbook Pro?? I was told the Acoustic Energy - Aego M is very good, but would that be as good as Speaker+amp combination for the same price?
I know it has Optical output and I need an external DAC to be able to use that optical output.
However, if I just connect from analog output (headphone) to the TA-10 (i found it well regarded on this forum) > then to the speaker, would that be capable of producing decent sound? I don't want to spend too much here, and I can't listen too loud either or else the dorm officer gonna kill me.
Having to connect to DAC > AMP > Speaker is a bit overkill for me. I just need a compact system, with good sound.
normally, half of my musics are encoded in Apple lossless and others in AAC 192 VBR.
Budget Limit for all hardware : 300 Dollars
Hope I expressed my situation clearly.
My friends recommend a good receiver and a pair of speakers instead. I dont know which way I should go, so any comments are appreciated!!
