Originally Posted by ironmine /img/forum/go_quote.gif
Well, I also like my NAD, I find it very musical and it paints really palpable sonic images, in my opinion. It just draws you in and doesn’t let you go. But when I started using April Music Stello HP100 as a preamp, I did notice that the sound became cleaner and more transparent. So, I hope if I invest my money to a dedicated power amp twice more expensive than my current integrated NAD (and more powerful in terms of watts), isn’t it going to improve the sound? Or am I wrong and need an antidote against upgraditis?
In my experience, at least, the inexpensive NAD's really do well against most amps under $1k or so. YMMV, as they say. My speakers tend to be easy to drive, which tends to be one of the key variables in how an amp will do in a given system, again in my experience. I'm not familiar with your speakers, so I have no idea what kinds of changes you may hear as you start experimenting. However, as another poster noted, amps often have the least potential for improvements if they are well designed. Personally, I'd be looking to audition amps in my system, with return privileges if it's not an improvement.
I actually went through exactly that when my old Mistral integrated died a few years back - I auditioned relatively inexpensive integrateds (up to about $600) from Marantz, Cambridge, NAD. The Cambridge did not do well with my speakers (Epos ES22 at the time) for some reason (I suspect it was defective), but I could have lived with the Marantz or NAD - at least until I auditioned the Portal Panache. But that's in a whole different price class ($1,795 new). It's the one that came closest to capturing some of the magic of the Mistral. Rather than relying on experience of others, I'd recommend going through a similar process.
If local dealers won't let you borrow a demo amp, limber up your credit card and buy demo amps on-line from retailers that will let you return no questions asked within 30 days - Audio Advisor, Music Direct, Elusive Disc all will do this and I'm sure there are lots of others as well. You'll be out shipping for any you return, but you will be in a position to answer your question yourself, with your system in your room.
JB
PS - another, very large audio forum is
Audio Asylum -- Audio Reviews, Audiophile Forums and Stereo Reviews The place gives me a headache, though - I rarely visit it anymore.
edit - I just went back and looked at your location - my advice works great in the states, I'm not so sure you'll find such an easy way to audition amps in Russia. I guess shipping costs might get a little expensive! Given that, I'd recommend sticking with the NAD until you can step up to a higher price class of amps (over $1k or so). Since the Mistral was a European brand, you might want to try and track down one of those used.
