AudioPhewl
- Jun 20, 2008
Hello all,
Can someone please explain the following to me. Burson Audio offer their discrete-component-opamp modules here, though I suspect the same answer would apply to any opamp installation:-
Burson Discrete Opamp
On their "Discrete opamp 101", they list a mod of solder a good quality foil capacitor (MKP caps) across the power intake (V+ and V-) of the Discrete Op-Amp. You can try different value capacitor between 0.1uf to 1uf. Different value and brand will yield slightly different result however; the rating of the capacitor should not lower than 50V:-
Burson discrete Opamp 101
To my mind, using an good electrolytic in this instance will make a lot more sense. Firstly, it will provide additional filtering of the power supply feeding the opamp replacement. Secondly, it will provide a far bigger power store for the opamp to tap into on demand.
Am I missing something? What would the indicated installation have over one utilising a basic, low-ESR electrolytic?
I've been talking to others about this, and feel I must be missing something rather obvious - but for the life of me, I can't see the logic in using a small foil cap in this instance...
Thanks... I'd love to lift the veil of confusion over this!
~Phewl.
~Phewl.
