Omark12
- Jul 9, 2011
Xonar cards do have GX 2.5 though. Which can do EAX 2.0 natively then emulate 5.0. But until we get a card with CMSS-3D and DH, we have to pick.
Correct. What I'm saying is when I got DH it sounds like i'm listening to 7.1/5.1 speakers. I like it better, I watch a lot of movies that have DD and DTS soundtracks that are emulated with DH, The directionality of the sounds still exist.
As far as having to choose between CMSS-3D Headphone and Dolby Headphone, that is a bit unfortunate that we can't have both at the driver level and decide for ourselves, but there's always the option to get an Astro Mixamp, Turtle Beach Ear Force DSS, JVC/Victor SU-DH1, or other similar device. (Too bad that limits the analog output quality to whatever those devices are capable of.)
I'm pretty sure the DSS and mixamp are just Dolby Headphone processors.
As far as I know CMSS-3D only shines in games with OpenAL and Direct sound 3D right? In others you just have to use CMSS headphone with the 5.1/7.1 option in-game?
i was playing around with gaming settings on my X-Meridian and i hated it... sounded horrible and somewhat echoey, as if being in a stone room
if this is what eax 5.0 and cmss3d is like i will not use these settings, instead relying on the analogue headphone output, paired with some cans with great soundstage instead
anyone give me any feedback on the sound of these settings?
if this is what EAX 5.0 and cmss3d is like i will not use these settings, instead relying on the analogue headphone output, paired with some cans with great soundstage instead
That's because they all are. Feed them a Dolby Digital signal (DTS also works on the SU-DH1) over S/PDIF or Dolby Pro Logic II over analog, out comes a two-channel analog signal optionally processed with Dolby Headphone. When the X-Fi cards can do Dolby Digital Live, that's not an issue, and it's how I compare the two.
CMSS-3D Headphone excels in DirectSound3D and OpenAL games because it has access to the 3D sound buffer itself, yes. For games with software audio engines, they read the Windows speaker setting to decide how the audio should be pre-mixed before it even hits the sound card driver, so CMSS-3D Headphone effectively gets dropped to Dolby Headphone's level in terms of how much positional information it has to work with, being forced to emulate 5.1/7.1. It still reasonably works well in that state, but the lack of height cues is glaringly obvious. (Especially in games like Just Cause 2 with quite a vertical element to the gameplay.)
Summary: Set Windows to 5.1/7.1 and X-Fi to Headphones for maximum compatibility. Downmixing of extra channels is done whether CMSS-3D Headphone is on or off, so don't worry about missing sounds.
You shouldn't be using any EAX/environmental presets in the sound card control panel that add tons of reverb to everything. Those should be off at all times for exactly the reasons you've noticed. The point of having EAX is that the game engine has them mapped accordingly without needing tweakery in the sound control panel, and the sound card can handle it on its own DSP. Usually, the software audio fallback omits the environmental effects entirely, which isn't ideal at all because you're missing the intended sound. Worse off, it may have a limited number of channels, meaning that if too many effects play simultaneously, you won't hear some of them.
On a genuine X-Fi, EAX effects in games shouldn't have exaggerated reverb unless the game developer intentionally set it that way. The effects should be more subtle, with smoother transitions. Battlefield 2 and 2142, for example, certainly don't sound echoey at all in X-Fi/Ultra High mode.
It's certainly not easy to set a sound card properly for PC gaming audio, not helped by how they throw around buzzwords like that. Sooner or later, I'll have to write my own guide to sound cards and PC gaming audio, but since I don't own any modern sound cards that don't use X-Fi DSPs, it'll be tough to sort out your case as a C-Media user.
Just know that you're applying impressions on a C-Media card to how X-Fi cards might do it, which in essence means you're comparing an emulation of EAX 5 to the real deal and not sampling CMSS-3D Headphone at all, though in games with software audio engines, I can't tell enough of a difference from Dolby Headphone to say that one is better than the other, so you can safely carry those impressions over as to whether or not you like binaural surround filters. Some people don't like them at all and just game in stereo.
The X-Meridian and most Xonar cards use the same audio processer, the C-Media Oxygen HD CMI8788,
Asus just relabels their CMI8788 the AV100 & AV200.
None of these sound card come with CMSS-3D or true EAX 5.0
But they do come with Dolby Digital (like Dolby Virtual Headphone).
In some games, setting the game's audio to "Theater Cinema" works best, if the game offers the "Theater Cinema" option.
would you get the Titanium HD or the new Creative SB Recon3D PCIe (which has an inbuilt amp, but looks like no 3dcmss) http://www.amazon.com/Creative-Blaster-Recon3D-Fatal1ty-SB1356/dp/B00654PTT2/ref=sr_1_2?ie=UTF8&qid=1324671276&sr=8-2 ?
i was thinking initially of the Xonar Essence STX but i think ive been persuaded to get the gaming cards as i mostly do gaming!
they will likely be paired with an AD700 (with its huge soundtage).. but part of me wants to do something crazy like getting a Hifiman HE-500 or Audeze LCD-2... but i wouldnt have any money left over to drive them with good amps so this is probably a stupid idea!
i was however interested to ask you how the soundstage of the AD700 would compare with those expensive cans, and how would they fair for gaming!
http://vr-zone.com/articles/creative-s-sound-core3d-gets-nekkid-in-front-of-the-camera/14353.html
seems as though it isnt very good
btw, does EAX work in windows 7?
ive read somewhere that there are problems with it and Vista??
so im likely to go with the Titanium HD + AD700 (unless i go with the HD 800 lol - any ideas how they are for gaming?? reviews suggest they have some of the biggest if not the biggest soundstage out there)
Up through Windows XP, EAX worked fine,
Microsoft changed how audio functioned starting with Windows Vista, EAX no longer functioned.
Creative Labs came out with Alchemy, which allowed EAX to work with Windows Vista and 7.
Audio Technica ATH-AD700 is great for FPS, but it is a bass light headphone.
ok cool thanks! do you know if it is just a one-off install?
