ProtegeManiac
1: On the other thread I mention in this thread, the response is that the big boost I want in the high frequencies will not result in 100dB if my baseline is 80dB. Is this wrong?
That depends on the response curve and EQ settings. If for example you're playing at an average of 80dB measured at 1000hz, but then the response curve has 4000hz at -3dB weaker or +3dB stronger than 1000hz, then adding +30dB to that will be different on either case. Add to that whether the EQ boost is peak or a high shelf EQ (bosst everything above a certain frequency equally, with a gradually weakening boost below the center freq).
You mention that it may be difficult to find an equalizer, amp, and headphones to accomplish this. That is why I started the thread.
We get that. What we're saying is that this isn't the way to get there either since the equipment can't do that...
2: Headphones specifically designed for people who are hard of hearing are designed to play that loud. Over amplification is the solution for the hard of hearing. No, I don't want to put my mother's headphones on at her volume setting. But she has never been given a warning that using her amplified headphones or hearing aids will further damage her hearing.
I know this is a little outside the box.
...and what I would do instead is just find a headphone that can fit over the corrective hearing aid. Like the HD800 thanks to its humoungous earcups.
