Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
I use the Clip+ with E5 and like them just fine.
Originally Posted by Hero Kid /img/forum/go_quote.gif I would recommend searching and looking more into combining a FiiO with the Clip+. From what I've seen the E5's amp is generally not of better quality then the one built into the Clip+, so if you just want the best possible sound quality, you should simply not use the E5. It depends what 'phones you plan to use and what sound you are trying to achieve. |
