Playback problem with foobar and FIIO E7
Feb 8, 2014 at 1:23 AM Thread Starter Post #1 of 6
Wiiffler
Hello.
I discovered a problem today with the playback options on foobar.
I have both Kernel streaming and WASAPI installed to have a bit-perfect playback. But there's a problem;
Foobar seems to be "taking over" any other sound source. No sounds will comes out of any other application, programs or games.
Nothing will work until I go in Sound>Playback devices and disable/re-enable the FIIO E9.
But it does more than just that. If I try and watch a video on youtube (or other flashplayer based sites.Ex: dailymotion or vimeo) the video will start, and after a couple of seconds, completely freeze. So thats my problem. This computer has 12Gb of RAM, an i7 and a good GPU, so i doubt its a performance issue.
So I know that WASAPI or kernel is to blame (All i mentionned happens with BOTH and with "push" or "event" options on WASAPI.)
The E9 is plugged via USB.*
Anyone knows what might cause the problem?? Or should I use the "DS" output of Foobar and give up on kernel and wasapi?
Thanks!
Feb 8, 2014 at 7:37 PM Post #4 of 6
"Foobar seems to be "taking over" any other sound source. No sounds will comes out of any other application, programs or games.
Nothing will work until I go in Sound>Playback devices and disable/re-enable the FIIO E9."
That's what WASAPI does. It mutes any other windows and application sounds.
"But it does more than just that. If I try and watch a video on youtube (or other flashplayer based sites.Ex: dailymotion or vimeo) the video will start, and after a couple of seconds, completely freeze. So thats my problem. This computer has 12Gb of RAM, an i7 and a good GPU, so i doubt its a performance issue."
As for this issue, it definitely sounds like a flash player issue, it should not have any correlation to Foobar and WASAPI.
Feb 8, 2014 at 7:58 PM Post #5 of 6
Mhmmm. Any way to keep foobar from "haggling" all the sound? Perhaps another bit-exact streamer? Of course, not kernel, since this one seems to be doing the same.
Thanks!
Feb 9, 2014 at 2:46 AM Post #6 of 6
Thanks!
Either turn off WASAPI, or just exit Foobar when you want to watch Youtube. That's what I do.
I believe that you can also just stop the music (not pause, stop) and it'll suspend the WASAPI output.
