vwap
Padawan.
- Dec 4, 2002
Hi all,
I've got an old Pioneer SX-1250 that I'm having problems with. I'm not entirely sure what's going on, but it outputs for about a minute before I hear a "click" and then the signal going dead. This happens regardless of what the input is.
I've noticed that at louder volumes (~11 o'clock mark), the sound returns, but at very high levels. I can't sustain these levels long enough to see if these, too, cut out.
This happens both using the speaker outputs and the headphone out.
Not having any speakers (yet), and not having fully moved in, I plugged in the fronts of my Klipsch Pro Media 4.1 speakers directly into the speaker outputs of the Pioneer. Would this be the cause of the problem? Are the Klipsch not suited to be driven by a receiver?
Using the headphone out with a pair of SR200, the same thing happens, and returns at the same point, so I'm not sure if this throws out my last theory.
Another thought I had was that there's something broken or blown inside. Reason being, There are two massive heatsinks on both the right hand side and the left hand side (both near the rear of the unit). The right-hand side is scorching hot, while the left-hand side isn't hot at all. The click I hear is eminating from the left side...
Any thoughts?
Thanks!
Any thoughts?
Thanks!
