Ok thanks both for your opinions. It looks my expectations were too high.
I didn’t have a chance to watch the videos but read the thread talking about how to differentiate the Sextett.
to build on the original Fostex, did you try it with other pads? Because I read it is better than the new rp. The Sansui ss100 that is an oem version is also considered one of the best vintage headphones. But the one I could buy would be the Nad oem since easier to get in Europe.
A
properly modified NAD RP18 will kick an AKG K240 Sextett's ass, but to modify it properly is no small feat... in fact you have to take the drivers out, and put them into a different headphone frame, and buy new pads, damping materials etc etc... and best to have a headphone measuring jig to make sure you're getting consistent modding results while you're at it.
My modified RP18 is basically a 'poor-mans-LCD2', has better bass depth and texture than an LCD2, but smaller soundstage and less detail.
In the end, I like it, but for most people I think it would be a wasted effort.
SO, really it's better to stick to modern headphones or the few vintage classics that don't require modifying or extra work to sound good.
I'd say, try out the early sextett - you can tell it's the early one, because the suspension headband has holes in it and the cable is does not appear smooth, but as 4 small cables in parallel.
Or if you want to try a planar like the NAD RP18, consider trying the Yamaha HP-1.
To be clear, the Sansui SS100 is not an OEM of the T50, it's a unique headphone all on it's own that has similar drivers and form factor, but not the same as any other.
It is more something between a Fostex T50(nad rp18) and T30, but not exactly like either.
It is also only considered "the best" because of a few highly verbose reviews from overly-excited collectors. In of itself, it requires significant modification to begin to compete with modern headphones, unlike the stock HP-1 which is already somewhat comparable, without modification.
Also it's good to remember that your 'best' is not going to be the same as someone else's 'best', so it's always good to wait until you hear it first.
