tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
Sorry, I disagree. I knew that the AD8397 does not like to be run in unity gain. I knew that it didn't have overcurrent protection. These two issues probably account for at least 80% of the failures.
I didn't release the design thinking that they'd still be problems. I tried to correct them in the three prototyping stages. When my latest prototype builds worked, I decided to release it. It turns out that my fixes just didn't have enough margin for the real world, though. We did need the "field trial" to find that out....now that we've got the results, I think the course of action is clear.
No, not really. "Mini3fying" combines two unrelated changes.
One puts the output impedance devices -- ferrites usually -- outside the feedback loop. The method suggested by AMB and adopted universally as far as I can tell is to cut some traces on the board and mount components in a hacky way, but all you really have to do is use bead type ferrites on the output wires.
The other change lowers the noise floor, but you can do that without any of the above changes. It's shown on the second page of the PINT schematic, and it most certainly is not "Mini3fied". The second page of the PINT is relatively recent, but the instructions to do what is expressed there were in the PINT's parts selection guide from the start.
In fact, the info was on my site before the PINT was even available: I put up the new "cranky op-amps" article and the op-amp noise calculator before I released the PINT.
Now why would you want to go and do that? PINT v1.3 is a flawed design.
I'll think about doing one more run. Maybe. Qualified DIYers only. I'm only doing this because of all the yelling about how people still want these boards, despite the known flaws. I don't understand it, but then, I guess I don't need to understand it.
You know, we're about at the 4th anniversary of the META42's introduction, and in those 4 years, I don't believe I've ever heard directly from any of the commercial manufacturers. Not once, positive or negative. And the only things I've heard from them indirectly are just commentary, no pressure of any kind.
There is no conspiracy to deprive you of PINTs. It's just physics.
I never was thrilled with the MINT. It was without question my lowest-end PCB design, even below the META42. I'd hoped the PINT would be the way I could raise the performance bar on the low end. That's why, in this next version, I will be continuing on roughly the same path, not going back to the MINT.
Thank you! I would hope more people would just wait to see what I'm going to do about the problems before they insist on me making more flawed boards.
Scarcity is often correlated with high worth, but not in this case!
Originally Posted by jl123 The failure rate is not Tangent's or the designs fault. |
Originally Posted by cire they should sound nearly identical, but the PINT has much higher floor noise. |
Originally Posted by splaz Seems quite a few want them still. Tangent would you mind if boards were made ? |
Originally Posted by kramer5150 I wonder if "commercial" Forum sponsors were complaining to that the amp is "Too Good".... and such? |
Originally Posted by Windchill Looking forward to anything Tangent comes up with. |
