Navyblue
- Apr 2, 2008
Is it advisable to build a PIMETA with the voltage gain stage bypassed, essentially turning it into a unity gain buffer?
With the above configuration, if the volume pot is removed, do I need to put resistors in its place?
My intention is to build a portable amp for driving efficient IEMs with the least amount of component in the signal path to minimise signal degradation. Would it be a good idea in comparison of conventional design? Would dynamic range suffer?
Btw, is PIMETA board discontinued? I don't find it on Tangent's shop. Or is v2 conming?
Thanks.
Thanks.
