mik000000
- May 13, 2006
Have v/strange problem with pimeta. I have finished amp except for bias transistors. Amp sounds wonderful. I have run it from 2 9v and from a tread set for 24v. I used the opa2132/opa132 opamps. Resisiter bank (r4-r8) is in a dip socket, and I have cleaned the flux from the board.
Voltage measured to all the chips checks out, and Iq is 35ma (without the led). There is no heat from chips and sounds seems perfect.
I also checked resistance between input ground and output ground. I believe this should be inf. When I connect the leads (with meter set to 200k range) the resistance shows approx 80k and then slowly climbs past 200k limit. When I switch meter to 2m range it shows approx 1m resistance and then starts to drop.
Am not sure if this is a problem indicator or just an amomaly of the meter.
Any thoughts?
Any thoughts?
