Pico Problem?
Jan 21, 2009 at 4:31 PM Thread Starter Post #1 of 5
imademymark
hi all i didnt want to start a new thread so i asked this on another thread but there isnt any replies
its just that i've started to realise a 'ssiii" + some soft cracking noise when i turn the volume switch, but this only happens with my sensitive livewires, and not my rs-1s
is this normal or should i be rightly worried?
Jan 21, 2009 at 4:50 PM Post #2 of 5
totally normal... dont worry about it. I get that with my SE530 and W3 but ionly when i'm not using my impedance adapter. maybe consider getting one of them. you can then use a higher range in the volume pot and that results in better SQ IMO
Jan 21, 2009 at 6:00 PM Post #3 of 5
This is totally normal. It shouldn't bother you that much unless you play around that much with the volume knob when nothing is playing. On a side note, I believe RSA amps exhibit this as well.
