Garbz
- May 19, 2004
Yeah that's the article I was thinking of when i wrote staples "Picture Paper"
Btw my method for double sided holes is relatively easy. I print a border around my artwork then TT one side only. I then get a drill, and drill holes at each corner.
On to the other sheet I cut a small triangle at each corner taking about 1mm off each line. That makes it very easy. Simply make sure that every line points to 2 of the 4 holes, iron, and bob's your uncle.
