I just got an AudioEngine DAC for my PC and I need to buy phono cable. Can anyone here recommend budget phono cable which will make the most of my sound?
I think you mean just normal RCA patch cables?
Like these-> LINK ?
I haven't heard the term "phono cables" in quite a few years
You are going from your DAC to an amp or a receiver?
You don't need to go crazy on uber expensive cables but don't buy the cheapest junk you can find either. Just get a reasonable set of cables and they should serve you well.
