busssy2333
- Sep 15, 2015
I've had these krk kns 8400 for a couple years and they are great. But the pads just both started peeling and now the foam is all the way out and is giving me a bad fit and a headache. I bought replacement pads for $33 which seems a bit of a rip off considering I paid about $120 for these and the pads probably cost literally $4 to make.
I don't think there's a cheaper pad that will fit but if anyone happens to know?
I know some pads fit other phone but not sure but is there another pair of closed back phone which are very neutral sounding (like the KNS8400) that has cheaper replacement pads?
I could super glue the pads peeling but I don't want superglue touching my ear and it would be harder than it seems to glue these. I was gonna stitch them instead but that might still be annoying and also not so easy to do.
I want something similar price $140 and under that is closed back, Neutral sound, and a decent length cord like 6 feet, not 3 feet. I am very particular with the fit though and have had to return other phones before just cause they don't fit right but these 8400s fit great as did the senheizzers they replaced before those broke.
