Alex Altorfer
- Apr 26, 2002
Hello Trent!
Basically the whole Phillips Clarity line (from the HP 800 up to the HP 910) features OFC cords, however, the 890 and 910 models feature a LC-OFC cord that is, a LINEAR CRYSTAL OFC cord. I don't know how big of an advantage that represents but maybe someone else may throw some light on the subject.
Not all models come with a removable cord. I believe only the HP 840 and the HP 890 feature removable cords. All other models, including (ironically) the top of range HP 910, come with cords that are NOT removable. The HP 820 is in every way identical to the HP 800 except for a more comfortable headband. The cord is non-removable and it is OFC but not LC-OFC. Mind you, the HP 800 is ergonomically correct and is comfortable enough as is in spite of the simpler headband design.
The earcushions are spongelike internally, but externally they are covered with a soft cloth. Its not velvet like the HP 890 and HP 910, but it is nice and comfy. It does get a bit too warm in hot summer days though.
As far as I know all the models have plastic earcups. I know the HP 890 comes with a metal grid added onto the plastic cup but all the others (even the 910 if I'm not mistaken) are all-plastic. The plastic on the HP 800 is cheap but it looks very nice and doesn't seem to be easily breakable. Mine fell a few times and are still in perfect shape.
I've auditioned a number of headphones by now, including the Senn HD 580/600 and the AKG 501. All these Sennheiser and AKG 'top of line' headphones sound significantly better than my Philips cans, but they are also much more expensive. The Philips HP 800 sounds great for the money. It's worth the forty dollars I paid for here in Brazil and it sounds much better than some of the lower range AKGs I've recently auditioned.
I use my Philips cans for an average of about three to four hours of music listening per day and I'm happy with them. My stereo is a bit old (an Optimus receiver plus a locally built CD player with AR OFC interconnect cables) but its warm sounding which helps smooth out the Philips' agressive qualities a bit. In my parent's stereo, which is much newer and a bit more accurate sounding, my cans sound harsh and cold. I guess it depends on what kind of stereo you plan to use the cans with. What's your rig setup like?
Cheers!
Alex Altorfer
Cheers!
Alex Altorfer
