OK,
mk3 vs SHP9500..
I have T50RP mk3 (HM5 Hybrid, HD600 headband pad, mass loaded, acoustipack in the inside, 4 of 8 ports taped, 3 of 4 vents taped).
Unfortunately I sold SHP´s 2 days ago for $125. They are really hard to get here in CZ, thus that price..
I sold them because I listen 90% of the time in somewhat noisy environment.
For me the only thing that SHP can do better sound-wise is some classic rock that don´t require deep bass, for example Stairway to heaven. Comfort is obviously one of the top features of SHP, but sometimes they feel like they will fall off your head..
Comparing these two is difficult, as they are different almost in every way, but personally I find mk3 as clear winner if you dont mind tinkering few things (not saying they don´t sound amazing out of the box, they do
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
That fast planar bass is just so addictive and it is really easy to customize (can satisfy both bassheads and ehm.. the opposite side), that´s I think the biggest difference between these two headphones.
Mids in SHP is nice and linear, but I had to EQ up the 2-3k region by about +4dB, it was simply missing.
Aggressive, forward vocals, that is probably why I love the mk3, but I listen a lot to metal and I can imagine that someone who likes for example jazz maybe don´t find it so amazing, not sure.
Treble here is most tricky to compare, SHP has better extension, but it seems little artificial and plasticky, maybe too much emphasized for treble sensitive ears, like mine
but treble can be tamed easily.
In mk3 there is audible 9k spike, which makes cymbals little more "metallic" than they really are, but after internal mods treble is more linear and sweet now. Still, there is big potential for modding. Also treble in mk3 is more forgiving in bad recorded songs.
mk3 has much better imaging mainly in games (csgo) and If you angle them, it becomes even better, so I´m planning to cut HM5 pads and take out some of the foam out to make them angled (hm5 angled is too thick imho).
They surprised me how open they can sound, considering the "semi closed" construction, which can also be customised from open to closed (t20 to t50 and t40).
Lastly I have to mention there is this feeling.. When you swith from SHP to mk3, you say ok, more bass etc, but nothing extra, BUT when you switch from mk3 back to SHP, you definitelly hear something missing
For me, deciding between these two was easy due to the price.
SHP for $120 or mk3 for $180..
If you can buy SHP for $60, it´s a no-brainer and if you can afford it, buy both
