- Jun 26, 2001
Hi...
Contact cleaner, yes... although to be honest, so long as there are no batteries / power going to the the player you should be able to put the cleaner onto the jack plug of your headphones, plug them in, spin them around a couple of times, and then remove... leave solution to dry, and then all should be good...
As to the pots, yes... LamerDeluxes guide is pretty much all you need, as to how successful you'll be, that... is purely random, although as you rightly say, its a very good idea to make note of the original position of the pots, incase you need to go back, and undo what you've done.
Good luck!
Duncan
Good luck!
Duncan
