jaddie
Account deactivated by request.
- Mar 28, 2011
Actually, once you're past A4 you can, do and must tune without referencing fundamentals alone. Tuning by listening to beats of partials has nothing to do with what reference you choose, it could be anything. The beats you are tuning and counting are beats between parietals, not beats between fundamentals, as the intervals you are comparing would result in fundamental beat frequencies far to high to count. Trying to tune each note individually to a reference will result in a horribly mis-tuned instrument.
The reference is used only as a starting point, and possibly for the home octave. In the case of a neglected instrument, you'd ignore the true 440 reference and tune the entire thing deliberately flat, leave it for a few weeks, then tune it all up a little at a time until you get where you want to be, and have broken all the strings you're going to break and replaced them.
You can't tune using beats without a reference pitch by definition.
