Perfect mod for AKG K702/701 -- simple, easy, no damage.
Mar 5, 2010 at 12:45 AM Post #31 of 31
Originally Posted by IPodPJ
UPDATE 3:
I moved the shaven stock pad back to the bottom. I then shaved the width of my pad in half and placed it back on top. So far this is the best result and I am very happy with it. Once I get some extra stock pads from AKG I will experiment with using certain types of glue to layer them together. I am looking for acoustically transparent glue.
'Sounds' like the best-of-both-worlds!
I'd like too hear this mod made from one piece of material (no glue).
Thank you!
Originally Posted by yklee118
the modification consists of a synthetic chamois drying cloth, I purchased mine while in Germany since I purchased the headphones at the Saturn Electronics Store in Hamburg right across the street from the main station (Hauptbahnhof). With the settling of the drivers and the mod, please refer to the thread as indicated by "Happy Camper", the spatial imaging is much more solid than with the stock foam rings. The listener receives a rather neutral sound spectrum as opposed to absolute clarity without any of the punchy feeling that most of us are accustomed to when coming from the upper end of the spectrum.
Thanks for sharing the info.
[size=small]Driver with stock pad[/size]
D'oh!
Originally Posted by magicalpig
One has to wonder about the worth of a diy foam mod on high-end headphones such the K701 when I'm pretty sure a lot of time, effort and expertise have gone into designing them....
When you put something in front of a spk it doesn't perform the same as if nothing were in front of it.
To cover my cost of shipping, I will send them out to you for $1.40 each plus postage (probably only 44 cents).
Shoot, I'll give you two bucks & fifty cents for postage; five bucks for a tweak are you kidding me?!?!
