Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
When every producer and musician I know proves that it exists, and has for over 20 years now, nothing you can post will convince me it doesn't. Such strange types, the lossy defenders. You truly believe that your body can't distinguish between the same song coming at you using 320k bandwidth or 3200k?
It's so obvious to me when hearing hi-res music that it's amazing you want a test to tell you it's the same as lossy. Is there anything else in your life where you believe that your tests show that math and industry experts are wrong?
May I reference you to http://www.grammy.com/quality-sound-matters to find all sorts of experts that clearly disagree with you. The people that actually make and distribute music disagree with you. Scientists and internet physicists can't tell you anything about making and recording music, because they have no clue. Your experts are the wrong experts.
If there was no difference we'd all mix with lossy tracks --- so much more processing power available, so much hard drive space saved.
You have submitted zero evidence that you can reliably distinguish between them under controlled conditions. All you have done is make claims without any objective data to back it up. If you want to prove that you can reliably distinguish between them, it's easy to attempt to do so: just take a lossless file and convert it to high bit rate lossy (or a hi-res file and convert it to lossless Red Book) with dBpoweramp, then do an ABX test and show your results. If you cannot pass 15 out of 20 trials, that means you cannot hear the difference. Period.
I'm talking about playback of audio, not production.
This thread really should have been posted in Sound Science, anyway...
