Sound Rhyme DTE500
2EST+ 2BA + 1 Dynamic Driver Hybrid 2Pin 0.78mm HiFi Audiophile In-ear Earphones IEMs
Description
Hand polishing
Personalization panel
0.78mm connector
Resin housing
5 hybrid + electrostatic driver combination
Crossover capacitance
Detachable cable design
Three-channel sound guide system
Five drivers, dynamic, balanced armature, electrostatic configuration
Conventional electrostatic drivers require a special amplifier to raise the voltage to drive the driver. EIVEC wide-area electrostatic driver transformer, developed by EMPIRE EARS, has a miniature design, which can be flexibly used in earphones with complex driver structure. Ultra-high voltage transformer efficiency enables the electrostatic driver to emit high frequency up to 100kHz. Powerful internal processing design enables the electrostatic driver to emit accurate sound. Combined with other drivers, it brings three frequency average and natural timbre.
Low frequency dynamic driver: using three layers of composite film, driven by N50 NdFeb magnet, making the low frequency more smooth, natural and loose.
Balanced armature driver: using Sonion 2300 and Knowles ES30095, the balanced armature combination makes the intermediate frequency more solid and powerful with the sweet vitality of the voice.
High frequency/ultra-high frequency balanced armature: use of high-end Sonion one for two electrostatic driver, so that DTE500 sound texture and high frequency more smooth and bright, sound details more rich and full.
3-in-1 modular cable,Plug and play, clear conduction
Suitable for 4.4mm balanced/2.5mm balanced, 3.5mm stereo, compatible with most stage equipment and high-end players.
Precision transmission, three-channel sound tube system
Thanks to high precision 3D printing technology, the separated conduit structure was designed. The low frequency and medium frequency, high frequency and ultra-high frequency are independently tube to output the sound, so that the sound reverberation has a better processing and interpretation of sound separation and image.
DLP-3D printing technology allows the structure to break the imagination
DLP 3D printing technology is adopted. Under the high-precision 3D printing technology, the printing precision, printing efficiency and curing light uniformity are improved qualitatively. Each structural detail is more accurate and stable, and the exquisite internal structure is realized which is difficult to be achieved by traditional technology.
Biological adaptability, resin shell
Rugged, aesthetically designed, selected materials.
Innovation breakthrough, stable quality
Using egger skin-friendly resin, supported by high-precision turnover and CNC high-speed fine carving processing technology, each structural detail is more accurate, realizing the exquisite internal structure and appearance color that is difficult to achieve with traditional technology.
CIEM-like wearing experience, CIEM-like comfort
The excellent combinations of industrial design and ergonomics, the collection of thousands of human ear data model, the use of 3D high-precision printing in accordance with human ear structure, to ensure that the earphone provides comfortable, safe fit and effective noise isolation.
Make the cable with heart
Using single crystal copper plated thick silver cable, the material is full of 48 cores in each core. 6 strands 0.06X7 0.1X1 coaxial twisted Litz structure weave, the skin uses transparent and environmental protection TPU material, visible real material.
Specification
Model: DTE500
Driver: 1 dynamic + 2 balanced armature + 2 electrostatic
Frequency response: 20Hz-22kHz
Sensitivity: 112±3dB
DC impedance: 17Ω
Sound insulation: 30dB
Cable length: 125cm
Connector: 2pin 0.78mm
Plug: detachable L-shape 3.5mm stereo/4.4mm balanced /2.5mm balanced plug
Purchase link:
https://penonaudio.com/sound-rhyme-dte500.html
